need help with alpha one gen 2 strendrive shift rod correct position
elvaktran
HI, yesterday I was replacing the lower housing shift rod bushing and when I took the the assembly with the rod out I forgot how to mark the position of the rod. now i really don't have an idea of how to put it back in the correct position where it can shift with no problems. I got the seloc online catalog but it don't explain clearly how it got to be positioned, just "port position" / if somebody has messed with it and knows the advise will very welcome!
thanks
will
If you can get it back in...... Then remove the bushing first to make it easier
put the shaft back in. Insert the shaft so you can shift. Turn the shaft clockwise and the prop c clockwise
until it locks. Now remove the shaft keeping pressure on the prop in a c clockwise
direction. Install the bushing. Insert the shaft with the tip facing forward (12:00)
this is the correct position for the shaft. This is foward and the u shaped link in
the gimbal housing will line up as long as ur shift handle is in forward also.
You may be able to leave the bushing in place but if you have trouble engaging the splines on the end of
the shift shaft u will have to remove the bushing to get it engaged to find foward.
