piper_flyer
"Hi all,
I am new to this f
"Hi all,
I am new to this forum and new to the boating scene. I recently purchased a sea-ray which I use for Lake MI. salmon fishing. It has the 351 ford with a rochester 2 barrel carb. The boat ran great at idle for hours and at high speed. Latly within the last couple weeks the idle has been giving me fits. It will run great for about an hour and then the engine starts surging and running rough and eventually will quit. When it first started doing this it would restart right away, but last week it would take longer each time. At one point I was bobbing around the big lake 6 miles out at 10 o'clock at night for a half hour trying to get it started. I did all the usuall things such as fuel filter and what not. It has great spark and the timing is correct.
So this week I performed a experiment. I hooked the hose up in the driveway and let her idle for about a hour and a half. After that it started acting like it does out in the lake. Finally it quit. I pulled a spark plug and the tip was white. A friend told me I had better get the carb rebuilt which I did. So last night I bolt the carb back on and let it run for about an hour. It seemed like it was running well, but when I turned the key off and tried to restart, it would not, nor would it even sputter. I sprayed some gas down the throat and tried again....No luck. I am very baffled on this one."
I am new to this f
"Hi all,
