According to my marine mechanic I have exhaust coming up thru the shift rod hole in my motor. It is being sucked into the carb breather compartment and the engine stalls at idle. With the cowl on it will stall when shifting from neutral to forward gear. It"s not as bad with the cowl off. If I keep blowing the smoke away from the air intake it will stay running. Any suggestions are appreciated. Thanks, Tony
