I bought this motor about a month ago after it was stored in a shop for 8 years. It runs and idles great on muffs, but once under load it stalls and wont get to full throttle. It does run a lot better if you hold the choke in. I have cleaned the carbs, has good compression, good spark, and replaced the fuel filter and line going from filter to VRO pump. Motor was previously ran with pre-mix, so they did not have the oil tank. I plugged the oil line and disconnected the wiring harness on the pump. What could be causing it to stall and run like crap when in the water? I really need help with this. I just bought all new fuel line to replace everything in it, and hope that maybe somebody on here can help me out with other possible causes/things I should check. Thanks!
