Upon re-installing my recoil on the motor if I don't have a washer the starter pinion will make contact with the flywheel and some times turn the flywheel but then it will slant sideways and get jammed. Without the washer is also grinding away at the teeth on the pinion. With the washer the pinion is not making contact with the flywheel.... have never run into this issue before and have removed and put back in other recoils with no issues.. What am I missing?
No Washer
https://www.dropbox.com/s/zuis9zq1hh4jrue/Recoil No Washer.mov?dl=0
With Washer
https://www.dropbox.com/s/ht836qsb2z1jo0c/Recoil with Washer.mov?dl=0
https://www.dropbox.com/s/4dyvu51hmuskytj/IMG_5258.jpg?dl=0
Thanks for your help in advance
No Washer
With Washer
