Do you have the round yamaha multifunction gauges or the square command link gauges? I've attached a picture of the round tach and speed gauge wiring diagram.
Tach Gauge-
Coming out of the back of the tachometer gauge is 2 sets of harnessed wires, 4 wires in each harness. These 2 harnesses plug in to the engine harness, which stretches from engine to console. Then there are 4 free wires...yellow, blue, black, and green. These 4 wires with bullet connectors plug in to the corresponding colored bullet connectors on the tach harness (pictured, 6Y5-83553-MO). Yellow is power, blue is light, black is ground, and green is signal.
There is no grey wire associated with the tach. There is a grey wire from the speed gauge. See below.
Speed/Fuel Management Gauge-
Coming out of the back of the speed/fuel gauge are 6 free wires....2 black, grey, red, yellow, and blue. The grey wire and 1 of the 2 black wires connect to the fuel tank ground wire and sender wire. The remaining 4 wires plug in to the same tach harness as mentioned above. The red wire is battery.
The other side of the tach harnesses bullet connectors plug in to the corresponding colored bullet connectors to the control box.
