shaunleveque
Hi from a Newbie.
Sorry my first posting is a question and I haven't introduced myself previously.
I have been searching for help with a problem I have with an AQ211A V8 Petrol engine and came across this site and lots of helpful information. But, I think I might have more problems than I first suspected.
I recently partially re-built an AQ211A engine fitted to my Fairline Sprint. I managed to get the boat really cheap because of the damaged engine.
The damage was limited to the *even* cylinders side of the engine. An exhaust valve had jammed slightly open and the previous owner had continued to run the engine for a while. Fortunately, this didn't seem to cause any other damage to the engine. It was inspected by a marine engine engineer.
I had the head skimmed, changed the valve, seat and guide, and had all the other valves checked and re-ground.
I re-assembled the engine and re-fitted the distributor and all seems to run well with no load, and the timing seems to be OK (as long as I'm using the correct timing marks on the engine....Not sure about that.........more on this shortly).
I found the diagram (below) in another thread (kindly posted by RicardoMarine), so I've copied and pasted it into this thread for ease of reference (I hope they won't mind).
What intrigued me about this diagram is that I find my No:1 *seems* to be where the No:8 is on the drawing.
Maybe I've messed up big-time??
I cannot get any more than about 10 - 11 knotts out of my boat at the moment, and under load it will never rev to higher than 3000RPM.
Also, (and I don't know if it's relevant), the exhaust riser on the "even" side always seems to be much much hotter than the "odd" side after the engine has been run for a while.
Do you think I've got my distributor all wrong?
As for the timing marks. The marks on the pulley are clearly marked. But, there is a "saw-tooth" plate on the block that I assumed was the corresponding marks, and I assumed the larger triangular cut-out "tooth" is the one I should be aligning my marks with. I am aligning the appropriate timing marks with the deepest part of the largest "V" in the plate.
I have a good stroboscopic light with inductive pick-up, and the marks seem quite stable at the quoted revs. (6 Deg BTDC @ 750rpm and 14 Deg BTDC @ 2500rpm).
I have checked and double-checked that I've got the firing order correct.
The engine seems to run smoothly and starts quite easily with no smoke and no excessive oil consumption. I have no idea of fuel consumption at this point.
It just seems to lack enough power to get me onto the plane.
All and any help would be greatly appreciated.
Thank you,
Shaun.
Quote:
Originally Posted by RicardoMarine
Same as any other SBC.
Keep in mind that how the distributor installation idexed the shaft, the rotor may not be pointing to # 1 when # 1 is at TDC C/S.
Is it NOT mandatory.... but does make sense to do it this way.
Thank you,
Shaun.
