DavidW2009
I downloaded the online Cobra repair manual. I've read the part on removing the adapter plate that's in front of the impeller/wear plate (the thin S.S. plate). I removed the two screws retaining it. I've seen the photo in the repair manual showing a pair of vice grips locked on the land area between the lower ports, and read the instruction on "carefully" removing the adapter.
The adapter in my outdrive is solidly stuck in there. The whole boat moves without any movement between the adapter and housing.
How is that plate removed?
