Need help on my 1996 Johnson 50hp engine- NO SPARK!!!!!
Corndog
I replaced the ignition coil on the engine because i thought that might be the problem.... Well it was not. I don't know what else it could be except maybe the power pack which i hope its not ( its very expensive) can any one think of what might be wrong?
Thanks will try that and get back to you
So i looked at the yellow/black wire and could not find a way to disconnect it but the engine is like new so the wires should not have any pinches in them so i was wondering if the stator may have corrosion or rust on it not causing it not to send Anything what do you think?
No need to worry about corrosion or rust on the stator.------You should test the windings ( charge coil ) in the stator and the windings of the sensor coils.---A factory manual is cheaper then guessing on these motors.
