Need Help installing cooling system hoses
Cconti17
Hey everyone! I searched for weeks & could not find a diagram to where hoses are hooked up for a 1973 Penn Yann tunnel drive with a Chrysler 318 in it. Can anyone please help me with this? I am attaching what my guesstimation of where to place the hoses. (Boat was inherited by grandfather who passed which winterized it last) could someone email me so I could provide pictures
not enough info given in your post...
Is the engine have a heat exchanger?
no pictures attached...used to be new members needed at least five posts before permission was given...there is a separate forum where you can make the filler posts...
No heat exchanger, water pump has 4 outlets, two going down and two going up & thermostat only has two outlets. Could you email me? Cconti17 @ gmail so I can attach pics
when you describe the "water pumps", when there is more than one involved, always specify which one you are describing....for example, "the raw water pump has the rubber impeller inside of it"...
no it’s just one raw water pump that’s connected and belt driven by the engine. I wish I could upload a picture because it is very hard to describe each component & Be specific on what each thing actually is I am not an expert by any means. Every time I upload a photo it says something went or photo is too large for server.
understand...but you have much more information than we do...
If the pic is too be, you just have to resize it, to a lower resolution.
I thought I emailed you the best diagram I could find from the factory manual...
