Another problem with my ignition, The engine run normaly but shut off after 15-45 min, after he won't restar. I have test with a DVA and thats my results: Switch box blue lead 305 VDC ( engine not run ), Switch box stop circuit 302 VDC ( when engine run at 800 rpm ), Ignition coil primary 190 VDC ( when engin run at 800 rpm). Stator impedance 775-777 ohms. Trigger 1333 ohms 1336 ohms 1338 ohms. Coil primary 0,2 ohms and 2nd 1001 ohms. I thinks the problem is from the stator, the stator output is below specifation, but i'm not sure, can you help???
