Mike from Atlanta
I recently bought a non-running 1973 Johnson 20 HP (20R73A). I have started the work of getting it running but I am new to outboards and I have a bunch of questions. I’m a fairly experienced shade tree motorcycle and small engine mechanic but I have never worked on outboards. I just bought my first boat (1987 MonArk 1448 aluminum flat bottom jon) then bought the this outboard on the cheap to push it. I enjoy tinkering with anything with a motor so hopefully I can get this thing running without spending a fortune.
What I have done so far:
Questions:
Thanks in advance for any suggestions. Hopefully it runs after the carb rebuild. If not maybe I’ll look at the ignition timing unless anyone can think of something else I should check. I’ve never worked on a points-type ignition so it should be interesting.
- Bought a repair manual. Wasn’t sure which one to get. Ended up buying a vintage factory manual published in 1973 on Ebay. All black and white pictures. Pretty cool.
- Built an outboard stand. I’ve got a plastic trash can for a test tank.
- Bought new fuel tank, fuel line and fittings.
- Tested compression. 102 PSI upper cylinder/99 PSI lower cylinder cold
- Tested spark. Pulled both spark plugs out, connected them to the plug wires, layed them on the engine block and pulled the rope. Bright, strong looking spark on both plugs easily visible during daylight.
- Mixed up some 50:1 premix fuel. Primed the bulb till firm (not sure what this is supposed to feel like). Pulled out the choke which appears to be operating correctly. Pulled on the recoil starter 10-15 times. Nothing. Not even a stutter. Pulled the spark plugs and they were wet. Used compressed air to dry the plugs and blow out the combustion chambers. Pulled the rope a few more times. Nothing. Dried the plugs chambers again.
- Put some premix in a spray bottle and misted it into the carburetor. Pulled the starter and this time it did stutter and back fire a bit but no continuous running. attempted this a couple of times with the same result.
- Removed the carb. Pulled the float bowl and it looks pretty clean. Like it wasn’t stored with fuel in it. While attempting to remove the high speed jet (manual calls it an orifice plug) I boogered up the screwdriver slot on the jet pretty badly. I used a grinder to make a narrow screwdriver to fit in the hole but I guess it didn’t fit well enough. Ended up having to remove it with a screw extractor. This arrangement of the main jet is unlike any carb I’ve ever worked on. Thought it best to stop the disassembly until I get the new carb rebuild kit in hand.
Questions:
- Does anyone know if the carb rebuild kit (marineengine.com part# 0396701) comes with a new high speed jet? It doesn’t look like it does, but every other carb kit I’ve ever bought for motorcycles and small engine stuff came with all new jets.
- If it doesn’t come with the kit, is $30.50 (marineengine.com part #0319534) average price for a new one? I’m used to jets costing $3-$6. Is there anywhere to get one cheaper?
- Looked up the special screwdriver (OMC 317002) for the high speed jet and they cost $30-$45. For a screwdriver. Ouch. Is there anywhere to find one for less? Or should I just try again at making one. May be easier to make one that fits the slot tightly if I have a new jet in hand.
- When I took the float bowl off there was gas in it. I don't know if this is because the fuel pump is doing it's job or if I pushed it in there with the priming bulb on the fuel line. Is there a way to test the fuel pump?
