JCosta
I need to check and/or adjust the timing on both my Crusader 220's (305 cid) but I'm not sure how to proceed. I've watched a couple video's but I'm not confident enough to do it yet.
This is what I have:
Actron digital timing light that I borrowed and it came with this other wire.
I was told it needed to be plugged into this port on the distributor, the one that has the yellow wire on it, then the other end to POS on battery
Now I kind of understand Initial Timing and Total Advanced Timing but I don't know what degree they should be set to. Is there an order that things should be done?
Ugh... If anyone has any helpful advice I would appreciate it. I just want to understand it before I begin.
Thanks, John
- Should I check/set Fast Idle first before I set timing and if so should RPM's be 700 or 750 at operating temp?
- Is Initial Timing: Advance @ 0 at TDC on the gun at 700 or 750 RPM's?
- Is Total Advanced Timing: Advance to 25 at 2500 RPM?
Thanks, John
