Need help 1982 Crystler 50 hp outboard
B
Bryan Center
Guest
starts good always. idel is ok
starts good always. idel is ok. Somestimes runs out full speed with no problem then starts to run bad then I can back off speed and it keeps running at 1/4 full. Bigest problem it starts to act up I can start it up but when I put it in drive motor dies. What is strange is that sometimes it works perfect but most of the time not. Please help!!
"History on the motor? did you
"History on the motor? did you just get this? had it for years? new problem? don't know?
It sounds very much like a gummed up carb - but could be bad plugs, old gas, clogged fuel filter, blown gasket.
Was this running fine and just started this? Was it ok last season and now since you have fired it back up this problem exists????
A little more background will definately help narrow down what "may" be the problem..."
"primer bulb going flat?
i wo
i wold try an aux tank and go from there
pull the plugs, what do they look like"
