Hi,
I am new to the boating world and i am going to try to make my story as short as possible
This summer i bought a Maxum 1900sr 2001 model with a mercruiser 4.3l gen + engine. I did not know anything about boats before this and not that much of engine in general. The boat looked great and only litte over 90 ours on the engine. The seller had change oil and filter before storing it for the winter. He did not pour antifreeze in the water system but drained the engine.
Fisrt day the enginge run good but when i took it out the second day it started to hesitate and misfire. After this my father in law took it out for a spin and it died completely. I managed to get the engine going again by replacing the coil, ignition sensor in the distributor, sparc plugs and fuel filter. But the engine would still misfire after it was getting up to working temperature.
I have spent many ours reading forums and the service manual and decided to do a compression test. It showed that there was zero compression on the left middle cylinder (other cylinders were in spec)
I have now taking of the cylinder head and it showed there was a leaking exhaust valve. The head is now sent to a machineshop to get it fixed but i wonder what can be the cause of all this?
There is rust in the manifold from water so i guess water has broken the valve. Inspecting the manifold, riser and spacer seems to be in pretty good shape, dont they?
I have pressure tested the manifold by poring acetone in them and check for leakage. Not a drop passed in to the exhaust ports. One thin i noticed when i worked with the engine is that one of the exhaust flapper wings has broken off and the tubes going from the carburator to the valve cover was not properly installed. The pushrods is also fairly rusty at the top near the rocker arms
I took some pictures of the manifolds. Should you replace this? they are fairly expensive here in Sweden
Excuse poor English
Kind regards Staffan
Excuse poor English
