Need advice AQ 140 alignment mystery
followingsea
"I recently set my low hours A
"I recently set my low hours AQ 140 back into the boat after new stringers, transom and some other major work. It will not line up on the alignment marks on the bellhousing but it looks lined up every other way. The exhaust pipe lines up pretty close to the exhaust manifold, the coolant reservoir sits very close to horizonal and looking at the junction where the big "O" rings sit (transom shield to bellhousing connection) it's squared up vertically and horizonally. But the marks don't align! The only thing I can figure is that the previous owner built up the crossmember where the motor mounts sit. Any reason why it won't work if the motor is sitting in properly EXCEPT for the alignment of the marks? The angled end of the bellhousing that protrudes out the back with the mainshaft sitting in the center--it's also sitting at a less than vertical angle.
I'm sending some photos. Take a look and tell me if it's okay. We tried lifting the motor and shimming it everywhich way but to get the alignment marks close the whole motor sits at a very odd angle.
AQ Alignment 1"">
AQ Alignment 1"">
AQ Alignment 1"">
AQ Alignment 1
"Dennis, was it lining-up befo
"Dennis, was it lining-up before you did the transom, stringers etc work? Chances are it wasn't. I would make sure that the engine is tilted in such a way that the exhaust manifold and the exhaust pipe line-up correctly and forget about the marks between the transom shield and bellhousing. I seem to recall (not sure 100%) that the AQ140 I had years ago did not line-up, either."
"Hello E.P.,
I don't kn
"Hello E.P.,
I don't know if it was lining up before or not.
I bought it from a guy who had pulled the motor and leg with intentions to convert the boat to an O.B.. He never got around to it and the boat, motor and leg sat in a dry shop since the late 90's.
I came to the same conclusion--forget those alignment marks. I've got the exhaust manifold and pipe lined up close enough to attach the rubber connector easily. Everything else looks like it's aligned pretty good to me. It was just bothering me that I couldn't get the thing to line up to the factory marks."
