Re: need advice
Let me see if I can clarify things a bit, I bought the boat & engine used, when I bought it the guy I got it from showed me how to start the engine, the choke lever is mounted on the engine and to start it one must turn the key switch which is mounted on the transom, it is a oblong devise with a key switch on one end and a button labeled "choke" on the other end. However the button does nothing when depressed, so, in order to choke it I must pull out on the lever mounted on the engine, so I must need a solenoid mounted on the engine in order for the choke to operate from the choke button mounted next to the key switch, my guess is someone converted this engine to electric start and didn't connect the electric choke and so I need to know what I need to complete the conversion.
