FishAtFive
Hello, I've been trying to get this 1987 Evinrude 50 HP running for a few weeks now and I am at a loss of what to do next. It's been sitting for about 4 years before I bought it.
Here is the status:
1) I have confirmed both sparks plug make a white spark
2) I have replaced everything from the fuel tank to the carbs (all fuel lines, primer celenoid, fuel pump, and the fuel manifold I broke)
3) Compression tested, both cylinders came in around 155.
4) I have rebuilt the carbs about 80%. I reused the old jet and float as they seemed ok. I could have removed the orifices but they seems to be flowining fine when I sprayed carb cleaner through them.
It cranks but will not start. With starter fluid it might get a pop or two, but does not catch.
I am at a loss of what to look at next. I can go back and fully rebuild the carbs, but I'm surprised even with the carbs being not perfect, I would think it would at least run rough.
Thanks for the help
Here is the status:
Thanks for the help
