even_kiehl
"Hello,
I have a Catalina
"Hello,
I have a Catalina 22' swing keel sailboat which I intend to use as a motorboat, no mast or rig. Will sell the two stroke on the boat and replace it with the 9.9 four stroke, EXTRA Long Shaft, 25", with a tiller and electric start.
I want to eventually have a remote control either in the cockpit area or actually a Yam tiller handle with shift and throttle mounted ON the sailboat tiller. (which I had on a 31' trimaran, not installed by me, but worked fine).
What is the best way to have the controls nearby, so I don't have to be leaning over the back of the transom for throttle/shift controls, pls?
Another alternative is someone selling a 8 hp four stroke Yam High thrust Long shaft, 20" with a remote box, 16' cables and tilt. The cables would be way too long, are shorter cables (6-8'?) avail?
The 8 is the length of my current two stroke (23") so would probably work, but I don't know if the cables could be changed for much shorter ones?
I would sell the 9.9 and keep the 8, don't want a bunch of engines, but both in excellent like new shape.
Any thoughts appreciated.
Area of use, btw, will be San Francisco Bay which is often very choppy
Thanks,
Stuart"
I have a Catalina
"Hello,
Thanks,
Stuart"
