Mystery evinrude
wer2nv4
Hi all.This is my first of man
Hi all.This is my first of many posts. I have just purchased a used aluminum boat that came with an evinrude on it. It has no stickers but looks like it is from the 60's and about a 9hp. The only number I could find on it was 301 924 under where it mounts to the boat. can anyone help me identify what the molde and hp would be?
Look on the cylinder for a nic
Look on the cylinder for a nickel sized
plug. That should have the model & serial
on it.
Evinrude puts their info tag on the transom
bracket.
I've attached a few pics t
I've attached a few pics to help identify this motor. I looked for the nickel sized plug but am unsure where to look. this is my first boat and motor.
"<[img]"http://www.marineengin
"Yeh, really small I know.
When is this site going to change to phpBB to make life easier?
Maybe someone can ask that question as well as me?
Dark Ages Mate!
I will attempt to send PM to you Steve Now.
Regards
Bruce."
Thanks Morten
But I am unable
Thanks Morten
But I am unable to zoom in or downlad the image from that site. I even joined as a member. any idea of model number or hp?
Ok I've got some more info
Ok I've got some more information now. I could not find a number on the shaft for the prop. But the number on the prop was 311484. On the side of the motor with the screws to remove the cover there was a number in the side of the cylindar on a plate 203253. Now there were 2 of these numbered 1 and 2. also the motor has Champion plugs j6 j. does this help?
"Steve
Take the motor cover
"Steve
Take the motor cover all the way off.
on the starboard side of the cylinders
you should find the welch plug with the info.
If you cant find it, try the Antique Outboard
Motor Collectors website. look for the
"Ask A Member" column.
http://www.aomci.org/index.htm
Steve A W"
Thanks but I'm not sure of
Thanks but I'm not sure of the hp or the model number yet. I would like to find that out for sure befor I purchase a manual.
