Hello and Thanks for Reading
'86 Bayliner with AQ260. Engine starts right up, sounds great, burns no oil. Easily reaches plane, runs strong and cool (Temp gauge shows under 180 degrees all of the time). There's no hour meter on these but it can't be that many.
However... If you run it for a while (20 minutes is enough) at planing speeds - just under 1/2 throttle - and then run it at idle speed for 10 minutes it refuses to run at more than approximately 1500 RPM until it completely cools down again.
Throttle up, at about 1/4 throttle the engine misses, cuts out, (but not misfires) - and you get the smell of gas.
What I've done to try and solve the problem:
1) Checked the ignition system - replaced points, rotor, rotor cap, plug wires. Ran a little stronger (as expected) but problem exactly the same.
2) Checked the fuel system - Fuel vent clear, fuel lines good, fuel filter replaced. When it was acting up, removed the fuel cap, didn't change anything.
3) Cleaned the backfire preventer (it wasn't that dirty)
4) The ignition wiring seemed a bit hot, fuse panel was a bit dirty. Replaced the fuse panel, cleaned every electrical connection on the engine. Got a higher reading on the volt meter with the engine running (From 13 volts to about 14), and some intermittent circuits in the cabin work solid now, but it didn't change the problem.
If it wasn't for the smell of gas when this happens I'd think something sticking in the carburetor, but as soon as you throttle back below the point where it misses it runs normally. It's getting more fuel than it can burn.
The only thing I can figure at this point is that the exhaust must be constricted somehow. Is there a flapper valve inside the manifold? Might it be barely open on idle and then won't open again when hot?
Any other suggestions? My mechanic has no clue...
