I have an 1988 Wellcraft with a MerCruiser I/O. When I turn the key to aux. all needles in gauges work. When I turn key to start the engine I hear a click and the engine begins to crank for just a 1/4 of a second. Then it stops and all gauges stop working and horn and blower stop working. It is as if I blew a fuse. Battery is fully charged. At first I thought is was a faulty egnition switch. Replaced it (twice) so I am confident that is not the problem.
Interestingly, when I let the boat sit for about 5 minutes, (without touching anything) blower will turn back on and horn will once again work and gauge needles will work again, until I try to start it, then everything shuts off again with the same pattern. It is as if there is some time delayed shut-off. I had it running about a month ago with no problems. I do not see any bad fuses. (Nor would I expect a bad fuse to heal itself).
Does anyone know what may be causing this?
H
H
