mvinesmusic
I have been chasing the cause of water in my oil for a few days. I first narrowed it down to the starboard side of my block. I found this out when I removed both the risers and found water down inside of the starboard manifold, and water vapor throughout the riser. So I thought that the pooled water inside of the manifold had to be from a bad gasket between the manifold and riser. I put on a fresh gasket sealed it up nice and tight, drained the old oil, new filter, and filled with fresh oil. Started up after ran okay for about 2min, then I noticed the same symptoms of bogging down. Shut it off, and checked the oil, and sure enough it showed milky signs.
So after come choice words, I took the riser back off, as well as the manifold, and I believe I see the flow of the troublesome water. I just need to know where you all think it is actually coming from. In the videos below you can see a small hold in cylinder 2 at the top, and it looks like the water is coming through there. Does anyone know what that hole is for, and how/why water is going in it?
Thanks!!
Thanks!!
