Mynewevinrude
r639243
"Morning All.
Just found this
"Morning All.
Just found this site.could have done with it long ago.
I have recently aquired an evinrude of unknown vintage and HP,I think somewhere between 5 and 10 but I am hoping someone can tell me from the serial # 5522-01274.Can't find a model nunmber I am afraid.
This little motor runs like a rolex watch and is as quiet as a 4 stroke.The only thing apparently wrong with it is the hinge T piece on the end of th gear change shaft is corroded away and there is a mickey mouse lash up involving sheet metal and hose clamps,or a grip wrench (don't like that idea much).
My question is/are: what year and model/HP is it.
Can I get the bits to fix the gear change shaft.
How easy /hard would it be for me to fix.I have mechanical aptitude and tools but ) experience with outboards.
I would appreciate any advice anyone can give.
Regards Geoff Graydon"
"appears to be a '61 5.5..
"appears to be a '61 5.5...u can prob find the parts u need,new or used...try sea-way.com"
"looking at my 61 microfiche,u
"looking at my 61 microfiche,u need to pull the power hd to replace the shifter arm...no big deal tho...the arm part number is--377580 it still is a good number...cost is 62.50 in the book.It is also listed as vintage,so i'd try seaway first,then a dealer,then,used."
"Just to add to the advice fro
"Just to add to the advice from JWB, you will probably need a new powerhead base gasket after removing it. There is no sealant used on that gasket, just put it on dry after thoroughly cleaning both mating surfaces. You should also use a good grade of Marine 2 stroke engine oil and mix at a 24:1 ratio."
