"I have twin Volvo Turbo Diese
"I have twin Volvo Turbo Diesels TMD22 (78hp) in my motorboat which I bought this year. Both engines have done about 1000 hrs. I had new injectors and cambelts fitted when I bought the boat as recommended in the survey - engine compression test was fine. Both engines have good oil pressure and run well but one will rev smoothly to 4500rpm and the other only reaches 3500rpm. The engineer who serviced them said that the problem could be the turbo on the low revving engine and could be expensive to fix and best left alone. I normally cruise at 2500rpm so it is not a major problem but I am not sure whether I should live with it or try and get it sorted out. What do you think? All comments and views welcome - Best wishes, Macky"
