My Prop broke
W
Will c
Guest
"Hello all yesterday while com
"Hello all yesterday while coming home from fishing I was cruising along when I decided to gas it up to 40mph to get a distance between me and the ferry. and one of the blades on my prop broke off.
I havent tried to take the prop off but, I was wondering if you guys had any tips.
also were would it say the size and pitch of the prop?
will"
"Hello scott I zoned out and f
"Hello scott I zoned out and forgot to say that it is a 270 that I have.
I was unsuccessful in getting the prop off but will try more tomorrow.
thanks, will"
"if there is an allen screw at
"if there is an allen screw at the back of the cone, remove it and then unscrew the cone. (screwdriver, or similar thru hole) if not, there is a locking tab washer in front of the prop. bend tabs away from slots, and unscrew cone."
"Ayuh,......
I Hope the pro
"Ayuh,......
I Hope the propshaft was Greased before the prop was installed.........
Otherwise,..... You might be in for a Fight......."
"whatever you do dont hammer i
"whatever you do dont hammer it off, as this could move the shaft on the bearings or the bearings in the houseing
use a puller"
Replacement Propeller Kit for
Replacement Propeller Kit for VP 290A Stern Drive.
Can anyone advise me where I could buy a replacement propeller Kit for my VP AQ151B engine which is fitted with a VP 290A stern drive.
The old propeller is a 14 x 19 L OEM Part No 854147. The drive spline has 17 Teeth.
I have tried Marineengine and Michigan Wheel but niether can supply.
I would be happy to buy a reasonable second hand prop if this was available.
Regards
Tom Struthers
