willow
I started this thread cause it has to do with the manifolds on the engine we are rfeplacing . We bought a long block and swapped oil pans with my old engine as the new engine oil pan had no windage tray and the new pan had the dip stick going through the block. We swapped in the old pan which had the dip stick in the pan, was on the correct side and has a custom fitting on the bottom for ease of removing oil using a 12V engine room mounted pump. The block was not machined for a mecahanical pump so we are going with an electric pump and all the safety features..no big deal to install.
This first photo os one of my manifold on the driveway with the riser not connected.(bolts are removed
The second photo is the main manifold standing on its end. Of note is the fact that a piece of gasket is over one of the ports and the other note is that there appears to be a piece of metal in a different port. I am not sure if that metal is part of the casting or a piece of solid rust...comments are welcome .
The last photo is that of the channels in the riser end and as you can see they have to be cleaned.((sorry/blurry photo//forgot to set macro)) I think because of the gasket over the port and possibly that piece of rust/metal in the channel of the main manifold ............that particular exhaust would sometimes steam and seem to spit the water out instead of flowing like the other three exhausts although I never encountered or even came close to engine overheating.
You comments are welcome and if you can direct me to a place for replacement gaskets it would be appreciate...it has been a long hard day and as of yet I have not snooped on the INet.
1991 Crusader 350CID
Manifold number 97753
Riser Number 98068
Need gaskets for riser to manifold........oh yes, I was asked to ask you experts...will high heat silicone do instead of a gasdket !!???
Thanks for your time
Riser Number 98068
