ricardomalinski
Thanks to all for helping me with my issues, I'm back on my feet and working on getting motor running. I replace the key switch and did find a primer selonoid that's now working. Did finally after many attempts get motor started in barrel of water at house. Thought I had problem fixed, But I took out for ride and only ran for 5 minutes, when engine just shut off, like it was out of gas, restarted, ran briefly, ran battery down trying to start. Took home charged battery and removed the hose from oil housing ran it directly to fuel filter, put oil in 6 gal gas tank. Primed while starting, engine started after few try's. Did this over 2 day's and engine started on first attempt, it's been a while since thats happened. I'm hopeing that was the issue with engine shutdown's ! Do you think that was the problem all along? Gonna take out on water tommorrow and find out, If not It's back to drawing board. But i'm excited about this time as the motor sounds and starts up like it did 8 years ago when I never had issues. I appeciate all feedback and I should of removed the oil system first and I realize that now. Rick
