My 1983 OMC Sea Drive 16 liter out board does not have spark
tim_l
"My 1983 OMC Sea Drive 1.6 lit
"My 1983 OMC Sea Drive 1.6 liter out board does not have spark, what is the problem?"
Remove spark plugs. Disconnect
Remove spark plugs. Disconnect latge RED electrical plug at engine. Crank engine by jumping starter solenoid. Do you have spark now?
"if I dont get spark after tha
"if I dont get spark after that, what would the problem be, last time I ran the engine it conked out, and when we got it home we had some water in the gas lines, could that of caused it? Can low battery power cause it not to spark?"
The ignition system does not r
The ignition system does not run off the battery---------The battery and starter must be topnotch to turn the motor over fast enuff to make the magneto produce spark.
The engine must turn over at l
The engine must turn over at least 300 rpm in order for the stator to provide the necessary voltage to energize the powerpack.
Low battery = slow cranking rpm = no ignition.
"what you said worked, now it
"what you said worked, now it runs. Would any body know how much horse power im getting with the 1983 OMC Sea Drive 1.6 liter"
