MR series alpha 1
jc1226
hey guys will the M.R. series
hey guys will the M.R. series out drive interchange with an alpha 1 gen 1 ???
thanks.
"thanks, do you know if ther
"thanks, do you know if there is somewhere i can put in a serial # of a out drive to find out what it is ???"
"OK, I thought this was a M.R.
"OK, I thought this was a M.R. but I looked on the link and looks like it is a 485 any idea if this model will interchange with a gen 1 alpha 1
by interchange i mean can i bolt the 485 leg onto the alpha 1 receptor. also thank you very much for putting up the link it was very helpful"
"The lower will, but the gear
"The lower will, but the gear ratio would be slightly different in the upper.The 470-488 inline 4 ,FWC Mercruiser used 1.84"
thanks again the serial # is 6
thanks again the serial # is 6166380 so i think i looked at the info on the link you gave me so i think i will try this and compisate the gear difference by changing my prop pitch. thanks again joe
