trying to get this boat going, changed cap, rotor, plug wires and plugs seemed to be running good now carb is flooding,still dumping fuel after engine stalls .has a carter electric fuel pump new rebuilt carb new fuel filter tank and lines .going to check the fuel pressure.
engine is like19 92 mp with 650 holley .is there a check valve in the pump .When I crank the engine and not start pump runs a little while with ignition on builds pressure then stops
Blue water dreamin!!!!!
