All boat owners know to well that one repair always leads to others. Mine started off investigating an engine problem and is now leading into a restoration project. I attempted to remove the starboard engine mount from the stringer, attached by two corroded lag bolts, and both snapped off. I drilled what was left and had a failed attempt to use a screw extractor to remove the remaining. I then did my best to drill out the remainder of the lag bolts with a depth of approximately one inch by 3/16 in drill sized hole. I didn't feel comfortable going any deeper, although it appears that there is more of the bolt below. My questions are: 1). Got any ideas for a custom mount to attach the engine mounts? 2). How deep are the lag bolts normally placed to be sturdy enough to keep the engine from shifting? 3). Are the bolts normally epoxied for more strength when originally installed? This boat is a 1977 Sedan Bridge with a 350 chevy Mercruiser 260 power plant. Any information shall be greatly appreciated.
