Hello all,
I just purchased a Lenco heat exchanger for my 77 vintage stbd side 318. My port side motor already has FWC. The exchanger is the kind that mounts above the motor behind the electronic ignition bread box. The problem is, Lenco doesn't manufacture the bracket kit anymore so they could only send me a partial kit that they had laying around.
The bracket I'm missing is the one that angles around the starter motor and mounts to the transmission. Does anyone have this bracket or know the dimensions so I can fabricate one?
Worst case I can remove the bracket on my port side to copy it, but I'm trying to avoid removing this bracket since it's bolted to the transmission via the transmission mount.
Thanks,
JJ
Thanks,
JJ
