Recently purchased a used Jon boat with a Motorguide 30 Tracker that worked fine. After stopping under a heavy weed load, it failed to work. I was able to locate the damage and repair the two wires that fused together and also replaced all the foot switches. All setting work perfectly but only after I hand start the prop. It has never been apart so what is the most likely culprit?
