motor turns over hard
xxtremebird
hey guys, i have a early 70s 650 merc that turns over fine with the plugs out . put them in and the thing barely turns over.... any ideas ? i tried a different starter,,two batteries,,stuck.could the timing be that far out that it could cause this? it was running not too bad a couple weeks ago then just crapped out .
Jump the starter solenoid...if it spins faster w/the plugs in replace it. If no better clean the battery and starter wire ends. Check for voltage drop on the cables. Replace if resistance is high on the cables.
Obviously cranking against engine compression requires more amperage. More work is involved.
On cleaning up things and resistance, as guy said, here's something to think about. The battery has about 12v available for starting. For the starter to spin up and do it's job it needs about 10v at the copper stud on the starter. You have 2 volts to play with. My 90 hp is spec'd at 120-160 amperes for starting. Taking the minimum 120 amps and 2 volts 2/120 = .0167 ohms. If you have a DVM just zeroing the leads on the ohm scale is 0.4 ohms.
Get the jist. On the solenoid as a problem, it is nothing more than two robust copper studs with a flat copper disc that is sucked down on the discs to carry the current. As they age, they pit and pitting reduces the surface area of the contact causing resistance. You don't have any room for resistance in the circuit as I explained above!!!!
On the terminals, clean and bright and tight. And we are talking about the inside where the current is being carried, not outside where you see it when it's buttoned up. If you have a cable with a corroded crimp terminal, get another.
When finished get your volt meter and put it on the copper starter terminal and the stud where the black battery wire is connected. If you don't get 10v while cranking you aren't there yet. If you do and it still does a sloppy job of trying to spin then I'd be looking for a new starter.
My 2c,
Mark
You just meed a 5/16" wrench to remove the small plate on top of the distributor to check the timing.----Look for the wee arrow found under there.------If it is out of time it can be changed / corrected without pulling the flywheel.-----------If belt is worn and needs replacing the flywheel will have to be removed.-----------Remove the starter and have it tested !
It's NOT timing. IF the motor will not spin over fast enough--with a KNOWN good battery and starter--and if you STILL have this problem after jumping the starter directly with some GOOD jumper cables, then you have an internal problem.
Just went through this with a Merc 500, and its problem was rusty main bearings--they were dragging and slowing the cranking speed. The starter worked perfectly on an identical Merc 500 that ran great.
Jeff
just tried hooking two sets of booster cables to the starter and still have no luck,,motor ran good a week ago so i guess im stuck with an anchor.
engine has 100/100/110 lbs compression so im stumped as to why its so hard to turn over,,maybe two bad starters but sure hate to look for a new one if its a lost cause
It's possible both starters are bad, but I'm thinking main bearing trouble. For heavens sake try another starter before tearing into it.
Jeff
Jeff
Jeff,
That's an interesting comment you made about being into another engine with similar problems and bad mains. In looking at the pieces here. He said it ran good a week ago. That speaks of recent lubricant and motion to the mains. Not conducive to rust buildup in my mind. I guess they are SS needles like the rod bearings? With that said, wouldn't you discount rust as a culprit?
I think he could pull the plugs, shifter in N, grasp the flywheel with a crank rope and pull it through by hand to determine internal resistance. If he can easily pull it through I wouldn't look for engine resistance as the problem; opinion! I started an 85 hp once with a crank rope (plugs intact). In my early years I only had a cranking battery and my trolling motor ran it down. It didn't take all that much effort to start it. Actually I was amazed it didn't, being 85 hp.
I want him to measure the voltage at the starter copper + terminal on the starter and starter ground....metallic end cap of the starter, metallic band around it, black battery - lead to engine block, but measure the stud not the lug attached, when cranking, plugs installed. I want to know what voltage is present. If 10v or more why not take the starter(s) to Autozone and have them tested like they do for automotive starters? If less than 10v clean up the wiring or take the battery to Autozone and have it load tested. It should have at least 11v at 200 amperes across the terminals with the tester.
Something about batteries. When lead acid batteries age the sulfuric acid reacting with the lead plates forms a sulfate scale that winds up in the bottom of the battery. When bad enough it piles up andshorts out the plates and can render a cell dead. 6 cells in a 12v battery so you lost 1/6 (17%) of your cranking power besides the series resistance (you don't want) in the high current path. With no current draw a bad cell may have enough static voltage left to make you think you have a good battery when you put a voltmeter to it.
One way of telling something is wrong is when you have a battery that you think is run down and put it on a charger only to find that it charges at a very slow rate and prematurely shows charged. You are expecting 12a on a 10a charger initially and it only runs out to 6 for example. Putting the battery under load forces each cell to contribute and if it's not functional it will show up in reduced voltage across the terminals.
Seems odd, but nothing says you don't have 2 bad starters. Where'd you get the second one?
HTH,
Mark
Just had another thought: It could be a bad Lower Unit.
Jeff
Yeah, outside chance. He could check his fluid and shavings on the drain plug magnet. I think if that were a problem, he would have known about it a week ago. I still think the pull rope test will eliminate the innerds of the engine. Just my thought, but I would certainly do it before I tore into anything.
Mark
Agreed. I've seen really hard to spin LUs that got water in them but, like you, it sounds hard to believe the LU would get that bad that quickly. Still....
Jeff
