Motor runs full speed sometimes
I have a 1984 115HP Evinrude with fuel pump conversion on it. Idles good, slow speed good, and fast speed good when you first give it the gas. But when you stop running and the engine has been sitting awhile, then when you start the engine back up and hit the gas, it will only get up to half speed like it bogging down. I did find a small gas leak on the one fitting on the fuel pump. Change fuel filter, hoses, put new carb.kits and cleaned carbarators awhile back. Any advice will be helpful . Thank You.
With the engine in the normal vertical running position, before starting the engine the second time, if you haven't do so, once again pump the fuel primer bulb up hard. It's possible that the fuel at the engine is siphoning back into the tank while sitting.
The siphoning problem can be due to faulty valves in the fuel primer bulb but more likely a "stuck open" Anti Siphon valve at the fuel tank (see below). Let us know what you find.
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
NOTE: There has been cases when the output valve in the fuel primer bulb would come apart, and the inner portion of the valve would actually reverse itself and be drawn back into the primer bulb's output valve body. This in effect would create a shut off valve and result in a fuel restriction. If this is the case, you should be able to feel something laying in the bottom of the primer bulb when held horizontally.
Are you implying that the fuel in the carburetors will siphon out?
