knuckle47
Advanced Contributor
I had briefly mentioned elsewhere in a comment that some PO decided to add about 100 lbs extra torque to the trunion bolts on one of my engines. It is becoming increasingly more apparant I may need to pull this one motor mount and work the bolt out of its' place. IF I can't remove it in its mounted position and decide to pull the mount, will it be sufficient with the tranny and v-drive hanging off the bellhouse, to just block the engine in place and do the job? Just wondering. Three other mounts will remain in place.
This FREAKIN job is merely a desire to move the engine slightly for an even closer alignment...should have left well enough alone. See what happens when you nothing else on the drawing board?
