Afternoon!
I have a 20 Ft Pontoon with a 90 Hp Mercury EPLTO. Motor runs great, the only issue I am having is a constant beep only at Wide Open Throttle. The motor is not overheating(Pees very strong, and the Power head is average temp and able to touch by hand even after running for a while). As soon as I throttle down a bit the constant tone goes off and wont come on at all unless I go WOT. From what I have researched, the constant alarm is for overheating, or possibly over revving.
I am wondering if I need to lower the motor an inch or so. Maybe its loosing traction or losing water flow at high RPMs. Thoughts on possibilities? Its a flat transom with no set back on the motor. I believe that does affect the answer to how low in the water it should be due to water displacement from the transom. (I tried to upload some photos but it will not let me for some reason. But the Cav plate is pretty much even with the bottom of the motor pod)
