i have a 2002 mercury 60h outboard, i recently replaced the water pump impeller and gaskets and shaft seal, it ran for about 5 minutes with muffs on, i shut it off then restarted it, it now runs then dies it acts like the water is not releasing and choking the motor, when it dies it bangs pretty hard, i pulled the lower unit off again, the shaft seal was pushed up the shaft, i made sure it was on the second time, it now still does it, i pulled the lower unit again, the seal is still installed properly, while it is running the water is being sucked in fine but looks like its not exhausting it very well, can the motor be getting choked out by water somehow? any suggestions?
