smoknmotor
99' Johnson 225 H.O. (J225HPLEEN) Carbureted.
So, I've gone through a few checks and replacements.
Replaced the tach and the vacuum switch for low fuel pressure. I repaired any bad connectors going to the tach, I've checked the grounds and I'm still getting a random tach operation and engine horn.
Does the powerpack, rectifier/regulator, or stator have anything to do with those two. At one time I had the motor drop Rpm's on its own and was told it could be a heat problem to the powerpack causing that. Another thing I was just thinking about is what about the power relay? Could that have a sensitive connection making my gauges quit. One minute they all work then they dont.
