More HP
Erik A. Larsen
I have a '86 21' Bayliner Trophy with a Volvo AQ 131 A four cylinder engine. This has a single carb a single overhead cam.
I suppose that it is about 130HP.
What is the largest four cylinder Volvo engine that will bolt up to the existing 275 OD?
Erik.
Erik.
Ayuh,.... The 1 you've got,.....
Sell the boat, 'n buy the 1 ya really want, with the Power ya want,.... It's Waayyy Cheaper,....
The AQ145 or the AQ151 in the single OHC version.
If up for more serious re-power, the 4.3L GM SBC could be adapted.
You'd need the AQ200B exhaust Y-pipe, and the 3" Barr exhaust manifolds.
The V-8 flywheel cover will be necessary.
The lower unit will need to be changed to the 1.89:1 ratio.
All parts remain OEM.
Couldn't be any truer. Having done many engine swaps for people over the years, this IS the best way to go.
I would completely agree with this if it wasn't for the ease of the AQ series regarding a swap like this.
I do agree if the OP does not have the skills to take this on.
If a person absolutely loves the boat..... why not do a repower?
Boats are never investments anyway..... they are always expenses.
We just use it up in the form of family fun and enjoyment. :D
Ayuh,.... Generally speakin', True enough,... Boats are Always an Expense,.....
Re-fittin' a hull can be an Investment, so long as it's a "Classic" hull, with a "Cult" followin',....
A Bayliner's gonna come up short on both accounts though,...
That was a very PC way to describe Bayliners.
Yes, it sure was! :D
I fully agree..... these older ones were perhaps not the best built boats out there.
However, the ole Searay -vs- BL argument falls a bit short with regard to some models when comparing like years.
You know that I own an old 2850 Bounty boat. The Bounty was a bit ahead of itself back then.
Even though, I am able to see some shortcuts that they made. The chopper gun follow-up was lousy.
