"Going thru my punch list of s
"Going thru my punch list of stuff to do since purchasing my boat 2 1/2 years ago. 1966 Californian twin 350 Crusaders. Its time to address the manifolds. Scale rust at the seam of the manifold to elbow (Raw sea water cooled old style NO risers straight shot)will be removing the elbows this weekend one at a time to check their condition. Anything in the manifolds that I need to be concerned with?? Ive found the castings on one. Its a Sierra 12-93 I believe the numbers to be the date of casting.
Question #2 What make manifold is better or does it matter listed by price that ive found Osco,Barr,Sierra being the most expensive.
Again I do not have an overheating problem. However Ive found no thermostats or pressure relief valves on either engine's housing.Hmmmm boat runs cool doesnt even lift the needle on the temp gauge off the 120degree mark. Infra red heat gun scan of the manifolds are at 113 to 116 degrees. 145 degrees at the exhaust point at the head. Sorry if this post sounds redundant. Know allot about cars this is my first boat and some things are different."
