I had a 45lbs Minn Kota trolling motor with Power Drive foot pedal, the propeller did spin, left and right turn working.I disassembled the motor, and measure the voltage between the brushes, it shows about 12.5v, so I assume the food pedal working, and I measured the resistance between two coppers, the value is the same, the springs look fine, so I assume the armature is working.
I heard most of issue will come from the brushes, but I only find the brush become a little bit curve instead of flat, is it the issue? any thought?
Peter
Peter
