Milky oil in engine
bresulani
I just change my engine oil 20
I just change my engine oil 20/50 right ? And I start it evrything worked nice and smoth and I got happy so I can take boat in the lake 2moro but but when I check the oil it was all milky milky and I change a lot parts over last year ...
what would hapen if I drive it 1or 2 days?
You need to find out where the
You need to find out where the water is coming from. Was it winterized? Sounds like something has busted. Driving it for two days is probably a real bad idea.
You need to start thinking abo
You need to start thinking about retracing what parts you changed out on your boat. Theres only a few ways that water can get into your oil.As of taking the boat out for a few days...... better find a buddy with a boat for that one.
"I change water pump , carb, i
"I change water pump , carb, impeler , s/p , cables, contacs, gas filter , oil filter ,and so and so ,"
"Was the engine and outdrive w
"Was the engine and outdrive winterized in the fall
"right know nothing I was hopi
"right know nothing I was hoping I'm done and ready for the lake ,yeah right allways something with old boats but I love it ."
"[b]"were should I star lo
""were should I star looking for water mixing with oil?"
Ayuh,... Again,.... What the 'ell you working on,..??"
"Ayuh,....
Drain the coolin
"Ayuh,....
Drain the cooling system,...
Isolate the motor, by blocking the hoses,...
Add pressurized Air, to about 15psi,+ Listen...
You'll Hear the leak...."
"[b]"so I have to remove t
""so I have to remove the engine out the boat?"
No,... Just block Off the cooling system passages at whatever points necessay,+ pressurize it with compressed air, at about 15psi..."
"over the weekend i removed in
"over the weekend i removed intake mainfold and heads (both) and i change all gaskets they were realy bad ,but i dint see the block crack, before i did that when i star the boat it was smoking a lot, and lot of water in oil pan ,after i finish there was only normal smoke coming out ,
but i still find a litter water in the oil but not so mouch like before
any edea please .....
thanks Benny"
yea i was about to say you sho
yea i was about to say you should check your head gaskets cause if the are gone youll get water in ... also you should check your exhaust manifolds for cracks and the gaskets you can get water in through those guys if your not sure take them to a shop and have them do a pressure test on them.. you might have a cracked head as well... also your gettting water in running it off a garden house right??
"jerod thank you ,yes im gett
"jerod thank you ,yes im getting water off garden house when i run ,but anyway i order a new 351 ford engine long block and i got a new exhaust manifold kit to, only thing im not sure shut i get a new intake manifold to ?"
well thats a question i really
well thats a question i really dont know the answer to what kinda of motor did you say it was 5.8 ford ..
man im really not sure the reason trying to give you some advice is just some of the things i did and i ended up stopping the water from getting in
