"What year?
The monitor bottl
"What year?
The monitor bottle is usually a milky white plastic squarish thing mounted front port side on V-8's or rear port side on V-6's, or maybe on the inner transom. It's about 5" high, has a black plastic screw cap on the top, and a 1/4" rubber hose off the bottom which goes to the inner transom plate. It should have a level of dark greenish drive lube oil.
It would be odd if your Gen II did not have this, as all Gen II's are plumbed for it from the factory, and as far as I know the monitor assembly comes standard with the power package. What year is it?
Rod"
