Barnaclebill1
Hello all I have a 15 hp that is dieing at half throttle and a quarter throttle on the way back last time I used it. Is this probably fuel lines ? If so what size should I have? Presently I have 1/4" line from the tank to bulb then from bulb to the fuel pump no inline fittings. They are about 2 years old . I took a cold reading of 98 in compression test for both cylinders . Also last year I changed one ignition coil . Just cleaned bowl as well
