kippstakes
I am working on a 6hp Johnson for a bud and right off the bat it has no spark on cyl 2 when pulled. I am used to working on larger, electric-start models. Where should I start here?
Thank you
Thank you
Even if only one coil is cracked change all three coils, points and condensers. If there is any slop up and down on the armature plate under the flywheel replace the mount and ring while you have the flywheel off. Another common wear item is the head gasket. If the compression is even but low pull the head and inspect the cylinders before deciding on spending much money on the motor. The motor is 43 years old if the cylinder walls are glazed over a quick hone and new rings and theoretically you can get another 40 years.
