doodah1
I have a 33HP - 2cylinder Johnson-RXEL-16R- on a 31' X 12' shop made (early 70's) barge. Original motor is 1968 vintage.
Lower gear housing, complete; was replaced many years ago. I don't remember the hp or year of the donor.
But it worked well.
First outing this year, motor died while idling in gear. Wouldn't shift into neutral from the remote station.
Motor won't start in gear. Had to (with some force) shift at the motor.
Pulled the motor and drained the oil. The first few ounces were "milkey" but remainder was okay.
With lower gear case on work bench, I could make it shift with the shift rod. All components look good.
Prop shaft turns smoothly with no looseness. The only parts that show some wear, were the shifting lever and cradle.
Remote station and shift cable work smoothly when dis-connected from motor.
IF I need to replace the clutch cradle. -- The image of the cradle on the web site is different than the existing.
And image for shift lever is a drawing. Johnson/Evinrude apparently used 2 different but similar designs. But the 2 parts have to match.
Are the sets interchangeable?
Any guidance appreciated.
Tried to post a pic. but that failed.
But it worked well.
