Ok
im asking the same questions again with a different model this time.
is there a wire output or anything that can be used to generate a signal or actually drive an hour meter on a MFS50A 4 stroke. Tiler steer.
understand that you canuse the self diagnostics same as the TLDI, however I like seperate gauges.
if no is there a 1/8 not port on the oil system that I can run a oil pressure switch like a traditional meter?
