MESSAGE FOR JOE 1996 MARINER 150 EFI
J
JIM PHELPS
Guest
JOE I POSTED A MESSAGE ON 6/2
JOE I POSTED A MESSAGE ON 6/23 ABOUT MY 1996 MARINER 150 EFI CUTTING OFF AND MISSING/ THANK YOU FOR YOUR HELP / I CHANGED OUT THE IGNITION SWITCH AS YOU SUGGESTED AND I ALSO PUT A NEW KIT IN MY PUSLE FUEL PUMP AND A NEW PRIMER BULB IN THE FUEL LINE RAN THE BOAT 4 TIMES WITH NO PROBLEMS THE 5TH TIME I TOOK THE BOAT OUT SAME PROBLEMS AGAIN / WOULD SHUT OFF JUST LIKE YOU TURNED OFF THE KEY AND WHEN RESTARTED WOULD MISS LIKE CRAZY AND CONTINUE TO SHUT OFF TIME AND TIME AGAIN ANY IDEAS? I STILL NEED HELP THANKS FOR ANY IN PUT CAUSE I CANT SEEM TO FIND A MERC. MECHANIC WHO CAN FIND THE PROBLEM NOW IVE SPENT 1500 DOLLARS WITH SAME PROBLEM THANKS.
"Jim.... I went back to that o
"Jim.... I went back to that original message of 06/23/01 "1996 Mariner 150 EFI Motor Problems" and read over what I had to say there. Sorry to say that since the Mariner is not my line of expertise and I was at that time simply comparing a similar problem in the OMC line, I can not think of anything to add. Hopefully another tech more familiar with your engine will jump in here with the solution to your problem. Good Luck.
Joe
